PV550 connection
rbenh
Jun 2008
Jenison, Michigan
This is likely an old question but here it is anyway. I am trying to download to an PV550, it has an RJ45 and a Pic connection on it. I used a cable that connectd to the RJ the last time i did this but that cable has since then ran off. What i ask is if anyone has the pin-out for the RJ45 to D9 to download? Or is it just a straight through cable?
Please provide the complete catalog number of your PanelView 550.
You will get much better help with that info.
I am not aware of a RJ45 to 9 pin cable for your serial port.
You will have to use a PIC or better yet a 1747-UIC ( USB to DH485 converter see PDF below). Or use a memory card to download your program to the PV. (see PDF below for more info)
Hey guys! I need to download my PB32 program to a Panel View 550 (don't have it right now so that´s all the specs I can give you) and I´m using a...
32
11,172
Need Helpppppppppppp Again: We Just Bought A New Pv550 Cat #2711-k5a2 Rev: B/frn 4.41/firmware Version 4.2. Rs Link...
2,887
Can someone tell me if I can use a standard ethernet patch cable to connect a SLC 5/03 processor to a PanelView 550 (2711-B5A2)? I found the...
5,155
Is there a way to add a stop to the attached program? I want to stop it after the first rinse so the operator would have to push a button for it...
1,229
I'm trying to connect a PV550 (2711-T5A2L) to a 1761-NET-AIC using a 1747-C11 cable (w/RJ45 removed) and the Phoenix connector. Can someone tell...
2,672
