PV600 Comms Problem
naegely
May 2008
Florida
93
I have a PV600 (2711-B6C9 PV600 Color Key/Touch, FRN 4.44) that I cannot figure out how to connect with.
This HMI has 2 RS-232 ports, one for printer (which cannot be disabled), and one for comms/programming. The comms port is connected to the serial port of an SLC 5/03. Communications are DH485, 19.2kb, everything works fine. Using my PCMK DH485 cable connected to the processor, I can see the SLC in Linx, but not the HMI.
I tried connecting directly to the comms / programming port of the PV with no luck at all. Tried both null and straight cables. Also tried downloading from PB32 using DF1 point to point rather than Linx without success.
I was able to make the program update I needed by loading from a memory card, but I would really like to find out what the trick is in case I run into this on another PV where I can't access the config menu.
Anyone have any ideas?
Thanks,
Rob
The DH485 over RS-232 swamp claims another victim !
First, about the SLC-5/03 controller's two communication ports; they are separate. Connecting to the DH485 network on Channel 1 will let you see the controller, but it does not "bridge" or pass through to the DH485 network on Channel 0.
When Channel 0 is set for DF1, you can "pass through" it to another network. But with DH485, I don't think there is any way to bridge through between networks because DH485 does not include the principle of "internetworking".
So, with the PanelView 600, the "9" indicates it's a DH485 protocol unit with RS-232 hardware. So, when you connect to it (straight through cable only) you need to be running DH485 protocol. On a built-in serial port, this is the "1747-PIC/AIC+" driver in Windows XPSP2. Otherwise it's via a 1747-UIC that converts DF1-over-USB to DH485.
Hi I am having trouble setting up the comms for the pv600 plus. I have ML1100 connected to a switch. The pv is also connected to the switch. I...
2,853
i have been struggling for a few days now on how to add a tag to a maintained button on a pv600 from a compact, ive done it on pv+ setup a...
3,553
Hello, A Customer wants me to get His SLC 5/03 PLC communicating with a PV600 2711-B6C8. Issue is.... The SLC has a DH485 port and...
3,298
Hey Guys. I replaced a PV600 ("old" type) today (worn out touch screen) but despite setting up the ip address and mask in the config screen, it...
3,257
I'm a beginner to PLC and Hmi programming. any one please help how to connect HMI to pc. HMI has a printer **** enabled by default, It does not...
432
