PVP HMI ActiveX macro for beginner
unsaint32
Oct 2012
minneapolis
365
I came across a Youtube video from Rockwell about using macro and ActiveX in PanelView Plus.
https://www.youtube.com/watch?v=7tbfloiyREY
So, I have to create HMI tag structure matching the PLC tag structure. Then I have to configure the macro button. And I use the ActiveX for the CSV..... As an inexperienced technician, I don't understand why go through all that trouble, when I can just create a shortcut to the PLC and write and read directly from/to the PLC tags.
Can you please educate me on why the macro and ActiveX are beneficial compared to the existing method of communicating directly to the PLC tags?
The Macro ActiveX is helpful when you need to:
1) trigger a macro from a PLC tag change (instead of a push button)
2) use more than five of those (Global Connections allows only five remote macros)
3) use parameter tags within the macro expression.
FYI: That video link is for the recipe activex. That's very useful for PLC tag triggers, as well as it uses plain text csv files.
just wondering what the consensus was on the PV800 HMI's when mated to a Micrologix 1200 or 1400 to control a single machine, non integrated...
2,544
Hi, could anyone help me to complete the communication steps of compact logix 1769 L2 controller, HMI (panel view plus 400 (key type) to the PC...
1,800
Hello, I made a small change to my FTV ME file (added an ack-all button) and re-downloaded to my PVP. Since then, when the application starts up...
1,026
Hello everyone, I'm seeing Japanese characters with a 90° rotation on a new PVP+7 screen. I post here hoping someone has encountered this issue...
760
I've got a relatively simple standard system with an issue that is frustrating us. Upon powering up the system as a whole, sometimes the Ethernet...
632
