PVP standard no ethernet on boot 'sometimes'
greatercontrols
Jan 2012
Lesmurdie WA
I've got a relatively simple standard system with an issue that is frustrating us. Upon powering up the system as a whole, sometimes the Ethernet just will not connect until power is cycled.
Often it boots and runs fine, but not always. We have many of these units out there. cycling power to just the HMI usually gets it going.
Hardware is relatively simple. On the PLC side we have a 1766-L32BXB Micrologix 1400 with just a single ethernet cable directly to the panel view plus standard. We have issues with both of the following similar models; 2711P-T7C21D8S and 2711P-T10C21D8S.
We've tried a variety of Ethernet cable brands, set the local date and time. power is supplied by a local 24VDC PSU that isn't driving solenoids etc. during the boot time.
I'm hoping someone here might have some insight from something similar?
Cheers
Found Rockwell document (ID BF21761) on their website. Need to sign in to view.
Basically says go to channel configuration for channel 1. UNCHECK auto negotiate and select 100 Mbps full duplex forced. Finally, cycle power.
Excellent! I'll give that a go and see how it pans out.
For all my searching, I could not have located that as I was sticking hard to the terms 'boot' 'powerup' etc.
The answers on here are usually easier than searching RA or Siemens websites.
Appreciate the assist, I'll post back on how it goes but it may be awhile as this fault is sporadic.
Cheers.
Hello, I made a small change to my FTV ME file (added an ack-all button) and re-downloaded to my PVP. Since then, when the application starts up...
1,023
Hello everyone, I'm seeing Japanese characters with a 90° rotation on a new PVP+7 screen. I post here hoping someone has encountered this issue...
759
Hi all, This is not a call to arms. I am submitting this solution for those who find this thread because they experience the same issue. I...
649
Hi all, i am running a PVP1000. The details are as follows: CAT: 2711p-rp6 Firmware: 5.00.04.55 (CPR9) I bought this version of PVP logic...
2,132
Many here have been bemoaning the missing VNC support in the new series B PVP 7 HMI. Good news, the new release of PanelView Plus 7 Performance...
1,589
