PVP7 Copy Files (logs) to USB
Boxy
Nov 2008
Sydney
57
Hi Everyone.
I am trying to copy my Data store plus files that are logging to my SD Card (Storage Card2) to my USB that I have plugged in.
I have tried using activeX control - ME Program Launcher to launch Explorer and to manually copy and paste the files that way. The best I have done is show the Start menu.
Is there a way I can either use Program launcher to call a .Bat file that will copy my Logging Folder across to my USB or allow me to call an explorer window so I can manually copy it across?
I'm not very good at DOS commands but I thought it shouldn't be to hard to find the couple of commands needed to copy the folder "\Storage Card2\DATASTOREPLUS\" to "\Storage Card". Would anyone know the commands for this too?
Only a subset of the DOS commands will work on the PanelView Plus.
Open the command prompt on the PanelView Plus, and type /? after any command you want to try.
If it gives you a list of help info, then use that (it might be different than what you find for Windows desktop).
You can also just type help at the command prompt to see a list of command; but I don't think that lists everything.
Hello everyone, I'm having trouble solving this one and was hoping someone could help. I have a AB CompactLogix L16ER PLC connected to a AB...
591
I have a panelview plus 7,and often popup a messagebox"application servicesd.exe encountered a serious error and must shut down"I refreshed the...
1,073
Hello everybody, struggling to make any sense of what this thing is doing with the time settings. 1. My PLC has a DINT[7] array with the...
3,086
Folks. Iv the luxury of replacing a PVP7 that got hosed down internally this morning. It happens here. I'm used to it. However, today, the...
5,226
I'm working for a customer who would like to replace local authentication on their PVP7 (FTVME 8.00) with Domain Authentication via LDAP. The...
1,872
