Q. about saving data externally w/ RSLogix 5000
FNC
May 2010
NJ
84
It has been a while since I used RSLogix 5000. Is there a way for me to save data in excel, notepad, etc??
I want data to be saved when a user presses a button on an HMI. Ideally every time it would add a new row of data on an excel file.
I believe Rockwell PLCs have a SD card but you can only write to it in Program mode which is not helpful.
Thanks!
Is there a Panelview attached to this PLC? If so I would use the DataStorePlus active X on the Panelview.
AdvancedHMI has an add-on EPPS that creates and writes data to an Excel spreadsheet
I have used that a few times for logging on controls.
I think you are referring to EPPLUS. It is technically not an AAHMI add-on, but it can be installed and use with AAHMI.
FTP is also an option , from PLC to a PC, btw.
Hi, I have a system that creates a text file that is comma delimited and it works great...in the US. I installed it on a computer in Germany and...
1,915
I'm using a 1769-L16ER-BB1B. I'm storing recipe data in an array of user-defined data types. For disaster recovery purposes, I need to make sure...
8,855
Simple question, is there any way of saving Function Block Output values on power down in Alpha2? Or more general question, is there any way of...
1,569
Hello all, I need your help to understand, How can I save values in DB to a Txt file in each cycle. Hardware used: CPU317F-2 PN/DP HMI: MP...
3,046
Hi everyone, I have to modify a program that has been running in the field for several weeks now. I would like to be able to save the tag data...
6,537
