Saving a Data Block into a txt file in every cycle
ajaysharma
Dec 2011
darmstadt
Hello all,
I need your help to understand, How can I save values in DB to a Txt file in each cycle.
Hardware used: CPU317F-2 PN/DP
HMI: MP 377, 12" Touch
I understood that I can use vb script to do this. Can anyone please provide me an example.
The sequence is as follows:
- Do a operation and record the data
- Process data recorded in a DB100
- Copy and move the DB into a excel file or CSV
-If possible, I would like to save the data in the same CSV file with maximum 1000 lines
-Clear the DB after each Cycle
Please let me know if more information is required.
Thanks for the help.
regards
Ajay
I'd recommend using a Data Log in the HMI, and logging the tags. f you want to do event based logging, instead of cyclic logging, you'll have to trigger it based on some tag or button.
I don't have an example, but take a look at logging in your HMI and the system functions related to it.
One question you'll have to ask yourself is "where do I want the files created/stored, and how do I need to access/use them?"
At every cycle? hmm going to eat up some resources....
I'd tend to save on change of data only.
Easy enough to copy the db and compare and then trigger a tag in the event of any change which can be used for the export
You state every cycle...i'm guessing to mean machine cycle rather than processor cycle?
I'd also go along with using the HMI to do the data export.
Thanks.. for the reply.
Sorry for the error, when I say every cycle it means the every machine cycle only. For every part the data is different and I am looking to save the data in a CSV file fro every part.
Please see the image and example text file.
[/QUOTE]I'd also go along with using the HMI to do the data export.[/QUOTE]
Could you please Provide an example?? How can I do this?
regards
Ajay
  • Example.txt
Hello All,
Working on the above problem, I wrote the below Script for MP377 Pannel.
But the code is executing without providing me an output. There was no file generated on the HMI.
Can someone help me with this?
'''''''''CREATE A FILE WITH NEW RESULT '''''''''''''''''''''''
Dim fo,FS, Path, Dataformat, file
Dim delimiter
Dim mode
Dim gap
Const NEU = 0
Dim csv
Dim Applicaiton ,WriteMethod
'Appeniding is used
mode = 8
delimiter=" ;"
gap = vbTab
csv = 1
'Code starts here
'Path = " \Storage Card CF \TESTFILE.TXT"
'Path = " \flash \TESTFILE.TXT"
Path = "\STORAGE CARD USB\ CARTDIAL-curve "
file = " \STORAGE CARD USB\ CARTDIAL-curve\TESTFILE.TXT"
On Error Resume Next
'CREATE A FILE SYSTEM OBJECT
Set FS = CreateObject("filectl.filesystem")
'Create a file object
Set fo = CreateObject("FileCtl.File")
'Check if there is any error
If Err.Number <>0 Then
ShowSystemAlarm "Error#"& CStr(Err.Number) & "" & Err.Description
Err.Clear
Exit Sub
End If
'Check for the Director
If (FS.Dir(Path)<>"") Then FS.MKDIR(Path)
if fo.LOF = Neu then
'Open or Create a File
fo_Open file, 8
'Wrting the Header
fo.LINEPRINT ( "Date" & gap & delimiter & "Part Id:" & gap & delimiter & "PeakForce" & gap & delimiter & "PeakForce Position" & gap & delimiter &_
"FinalForce " & gap & delimiter & "TransitionForce" & gap & delimiter & "S6.TransitionForceServoPostion"_
& gap & delimiter &"SmallDiaStartForce" & gap & delimiter& "SmallDiaStartPosition"& gap & delimiter &_
"SmallDiaEndPointForce"& gap & delimiter & "SmallDiaEndPointPositon" )
'write actual Data
fo.LINEPRINT( Now & gap & delimiter & SmartTags( "S6 CurrentETR.Data.PartID") & gap & delimiter & SmartTags( "S6.PeakForce") & gap & delimiter & SmartTags( "S6.PeakForcePostion" )& gap & delimiter &_
SmartTags("S6.FinalForce ") & gap & delimiter & SmartTags("S6.TransitionForce ") & gap & delimiter &SmartTags( "S6.TransitionForceServoPostion")_
& gap & delimiter & SmartTags("S6.smallDiaStartForce ") & gap & delimiter& "S6.smallDiaStartPosition"& gap & delimiter &_
"S6.SmallDIaENdForce"& gap & delimiter & "s6.SmallDIaENdForceServoPosition" )
Err.Clear
Exit Sub
End If
'Close the file
fo.close
Else
Err.Clear
Exit Sub
End If
fo_Open file, 8
'Write Data into the File
'Close the File
fo.close
End If
''Release the fileobject
Set fo = Nothing
'ShowSystemAlarm "Storage of the data was successful!"
SmartTags ("CreateCurveAnalysisDataRev01")= False
ShowSystemAlarm "File Saved in the Location" & Path
thanks for the help
ajay
It has been a while since I used RSLogix 5000. Is there a way for me to save data in excel, notepad, etc?? I want data to be saved when a user...
1,780
Hi, I have a system that creates a text file that is comma delimited and it works great...in the US. I installed it on a computer in Germany and...
1,917
I'm using a 1769-L16ER-BB1B. I'm storing recipe data in an array of user-defined data types. For disaster recovery purposes, I need to make sure...
8,861
Simple question, is there any way of saving Function Block Output values on power down in Alpha2? Or more general question, is there any way of...
1,570
Hi everyone, I have to modify a program that has been running in the field for several weeks now. I would like to be able to save the tag data...
6,537
