quantum and atv71
chud
Oct 2007
KALAHARI
1,123
Hi all
Got a question about comms between a quantum and an atv71 over modbus tcp/ip.
Normally I would do this using i/o scanning but for this client they cannot switch off plc so it has to be done manually with read/write blocks.
Now in io scanning you would read and write at register 1-11 (io scanning tables on atv71)
If i use normal read/write blocks I am not getting the values.
If however i read from the variables own registers ex. 40001 i do get values but I dont want to create a new read condition for every variable.
Thanx in advance for any help
Hi
Just guessing here (I always use io scanning), but have you set up the drive as if it was being io scanned, this should set up a block of data that the plc can then read/write using the readvar/writevar instructions. The block should appear at the address you would set up in the io scanning table.
PS I would be interested to know if this works
Hi Geoff.
When you use IO scanning do you use register 1-11 for reading and writing as shown in their examples in Unity?
Also i'm not sure that the standard in out tables on the atv 71 is the same tables as the ones you setup using the webserver. I think this is where my confusion comes in.Because the normal in out tables does have proper registers to read from unlike the registers 1-11 shown using the webserver io tables. I will ask the client to try the normal table. Think that will solve my problem. Will let you know
Setup the io scanning table using the web server interface. You can set up the table to read/write any of the parameters in the drive.
Yes you read from 1-11, but I think the data will actually start at 2 (this will contain the first parameter setup). I think the first word back is reserved (but I think you have to read it)
We did a quick test and you have to use the in out tables on the drive and not on the webserver. The tables on the drive starts at register 12761. So enter the values you want to read/write in these tables and then you can use normal read write blocks. If you use normal read/write blocks on i/o scanning doesnt want to read at register 1-11. It may have something to do with the tcp/ip address blocks map index
hi All Can you please help me to find the right software to open Zip backup of 434 12A PLC? Any major steps I need to know when opening? Regards
89
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
307
Hi There, I have a Modicon Quantum PLC, there is a alarm on display "noConfig" its happened after power failure, I have gone through manuals...
667
Hey guys. Mostly new to this stuff so I apologize if I'm not following proper format. I have 3 working CPU133 /3s. There is a desktop with a...
909
When i read the specification of 140CPU43412A i observe that as remembered in specification 1. Local i/o : Maximum i/p and o/p words are 64 in...
505
