Quantum MBP_MSTR function
pauly
May 2002
South Wales,U.k
244
I am attempting to use the MBP_MSTR function in Unity Pro V4.1 to get some local status from the NOE 771 01 card which we are using for some I/O scanning. I appear to have the function set up correctly but all I am getting is the error 16#2003. Any body have experience with this function?
What function code are you using - 3? What are the array sizes of your control and data blocks?
The third element in the control array is the number of registers to read, so the data buffer has to be at least this big. I think you can choose 0..37 elements to return, but whatever you choose, the destination array has to be at least this size.
MBP_MSTR Function
Thanks for the reply, I set the control parameters up in a table with the data buffer the same size as the number of registers expected. All I seem to get is an error code #2003, length error in control block!?!
Anbody have similar experience?
For the databaffer input I think you have to use the name of the first element of your array eg MyArray[0] and the array has to be located, eg the array is addressed as %MW100
hi All Can you please help me to find the right software to open Zip backup of 434 12A PLC? Any major steps I need to know when opening? Regards
24
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
281
Hi There, I have a Modicon Quantum PLC, there is a alarm on display "noConfig" its happened after power failure, I have gone through manuals...
658
Hey guys. Mostly new to this stuff so I apologize if I'm not following proper format. I have 3 working CPU133 /3s. There is a desktop with a...
901
When i read the specification of 140CPU43412A i observe that as remembered in specification 1. Local i/o : Maximum i/p and o/p words are 64 in...
502
