Quantum - Sy/Max Traffic Cop
boydkiefer
Jul 2009
Newark, NY
I am trying to add a Class 8030 RIM 127 (analog input RTD) module into a slot of a Sy/Max rack that is being used as remote I/O to a Modicon Quantum. When I try editing on traffic cop to "load" the module into slot #2 all the existing modules get a red "X" posted on them. I can't clear these X's away unless I remove (edit) the RIM 127 from the slot.
please help
Could be a problem with the version of card. I had a similar problem with the RIM121 module, series D worked fine but a series F card would go red (as yours does). If you are using Concept Schneider tech support should be able to help with a 'Modconnect' (I think) file. If you are using Unity you are probably out of luck. In either case you should talk to Tech support.
hi All Can you please help me to find the right software to open Zip backup of 434 12A PLC? Any major steps I need to know when opening? Regards
90
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
311
Hi There, I have a Modicon Quantum PLC, there is a alarm on display "noConfig" its happened after power failure, I have gone through manuals...
669
Hey guys. Mostly new to this stuff so I apologize if I'm not following proper format. I have 3 working CPU133 /3s. There is a desktop with a...
913
When i read the specification of 140CPU43412A i observe that as remembered in specification 1. Local i/o : Maximum i/p and o/p words are 64 in...
506
