Question about GE Series Six
hmudhaffar
Nov 2009
Dammam
i am installing a new PLC system using Allen Bradley Comapct logix. there is an existing GE Series Six ASCII BASIC PLC and we are requested to connect the new AB PLC to the existing one. of course the best way is to use Modbus card. can we connect the two PLC using modbus communication specially that the existing PLC is quite old.
Are you trying to make the CompactLogix PLC replace the Series Six or just communicate with it? What is the ASCI BASIC module connected to in the existing system?
The ASCII BASIC module in the Series Six runs a BASIC language program independent of the ladder in the CPU. I have compared it in the past to having a Commodore 64 in the PLC. While it is capable of acting as a Modbus master or slave, everything depends on the program it is currently executing.
Another possibility would be to install a CCM module and set it up as a Modbus slave.
We've got a sump pump which is switched on/off at the HMI by clicking a button on the screen then a physical pushbutton on a console, using this...
50
12,356
Firsts of all to make it clear I am novice at programming and controllers. I was called to a costumer who has four machines that do identical...
1,530
Hello everyone I'm just getting ready for level 1 electrical exemption exam. Someone suggested the following awnser to the following problem. See...
2,429
I have a Robicon 454GT series drive, and am noticing some weird behavior. It was configured to use analog input 1 (4-20ma corresponding to...
3,831
I would like some info on how to add to a set time with the touch of a button form the hmi. But first let me start with the process. The machine...
2,602
