Question about HSC in Micrologix 1200
brown56
Apr 2010
Indiana
Question about HSC in Micrologix 1200. I am trying to program a HSC in a Micrologix 1200. I can set it up in the function file and see the accumulated count but I am unsure of how to make it control the logic in my program. Any help on this would be greatly appreciated.
Brown56;)
It is a number. Use any number related instructions. A primary one will be the compare instructions LES, LEQ, EQU, GEQ, GRT or possibly the limit (LIM) instructions. Any will provide a TRUE output to use in the remaining part of a rung.
If you haven't already discovered it there is a quick start document #17447 on using the High speed Counter available on the AB knowledgebase. If you are using an encoder don't forget to change the input filter settings for the channel you use.
Hi, I'm doing a project with a ML1400 (1766L32BXBA). What I need to do is figure out the speed of the machine in feet/minute. I've installed an...
1,835
This seems like an easy one but I haven't found the answer yet. I have a micrologix 1200 and a program which uses a STI and IOM to control some...
3,923
Hello all. I am trying to get an encoder connected to an embedded HSC on a 1769-l24er-qbfc1b. This is how I wired it in but it isn't working at all.
964
I converted a program from ML1500 to 1769-l36 compactlogix adding a 1769-HSC. there is no 100 us option for the input filter in the HSC...
2,353
Hello, I'm setting up a HSC on a Micrologix 1400 with a Quadrature encoder. Everything is working correctly but I'm questioning my math I'm using...
1,441
