MicroLogix 1400 HSC question
Shawn Cassidy
Mar 2004
Montreal
98
I'm doing a project with a ML1400 (1766L32BXBA). What I need to do is figure out the speed of the machine in feet/minute. I've installed an encoder (1024 ppr) that is connected to a roller with a circumference of 12" so every 1024 pulsezs equals 1 foot. The encoder output is connected to PLC input I:0 for HSC:0 (up counting mode 0). This machine only runs in one direction. In other plc's I've used have the speed function to determine the incoming pulse frequency (Hertz), however this plc does not seem to have this function. I need to know the speed from start until about 3000 ft/minute. I see that using the high speed counter I can see the incoming or accumulated pulses at HSC:0.ACC, but I'm not sure how to go about manipulating the data to get what I need. Any suggestions would be appreciated.
have a timer count to 60 then reset. when timer is done divide acc pulses to get pulses/foot per sec
Hi, everyone I’m working on a registration project where I’m counting encoder pulses between registration marks. I’m expecting to see around 1800...
449
I am trying to program a Micrologix 1400 to control a beer keg filler using an IFM SM6001 flow meter. The meter will be set up for a pulse...
1,858
Is it possible to set up the HSC in the 1766-L32BXB as a ring counter. So it will roll over to 0 counting up and continue to count up that...
1,107
Hi everyone first of all. This is first question in the forum. I am using HSC application. I'm reading A and B pulse count. 1 round of the motor...
4,392
Is it possible to add a HSC onto a MicroLogix 1400 processor? I am using RSLogix500 and the toolbar has the HSC button greyed out. Is there any...
4,180
