question about plc which support modbus rtu
seyednima
Apr 2016
houston
Hello everyone i purchased a kinco plc k506 with modbus support .but most of the scada software (like ignition) required Ethernet port that my plc does not have it .my question is if i buy this product that i attach the link on below also attach a picture of the product am i able to convert modbus rtu to tcp/ip . or if i want to use advanced hmi that support modbus can i use rs232/rs485 to usb to connect it to my pc and use this software
http://www.ebay.com/itm/Serial-Devi...net-LAN-TCP-IP-Converter-Module-/291721611121
I havent used the product that you linked but in theory I suppose it should work. just make sure that the driver you use supports modbus rtu over tcp/ip. what the port server does is just encapsulates the serial data into tcp packets. I know ignitions modbus driver does support this mode.
some portservers have additional options, like a digi one iap, that will convert the modbus rtu device to actual true modbus tcp. this would be needed if your driver did not support modbus rtu over tcp/ip.
1.Does anybody know which PLC support DNP3 protocal? I know SCADAPACK support it, but any other PLC have same protocal? 2.May i have 2 dial up...
6,275
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
98
I've ready through the the previous posts, and we've worked with safety design for a long time. In the past, we worked with Pilz directly, and...
601
Everyone, i am in the process of purchasing the Slc 500 version of software to support what we have and i have a question. Several of our...
788
I know this can be done, but I can't get the router config right. My goal is to physically connect(using an ethernet cable) a device(PLC, RTU...
1,038
