question about rsview 32
stu
Aug 2005
England
786
Hi guys
Is it possible to transfer a rsview 32 project into a panelview plus project , the reason is I have a panelview plus screen in stock , trying to save the company money thanks stu
Short: NO
But you can import a RSView32 project into FactoryTalk View Studio SE (Site Edition), then you can make a new FactoryTalk View Studio ME (Machine Edition). You might be able to copy some elements but I think you more or less have to start from scratch.
Even if possible my experience tell my it would be a terrible project you end up with.
I think I would open both software and try to make the migration step by step manual.
I have worked with both system quit often, but never tried to make the migration between the 2 system, so I there might be someone else with better info for you. :)
If it is a major RSView32 project the PV+ cant handle it at all.
Not easily.
FactoryTalk View Studio can perform a partial automatic conversion of an RSView32 project, but FactoryTalk View ME (which runs on the PV+) lacks many of the features of RSView32 so it's unlikely the project will run without extensive modification.
Your best bet is to get a PC that can run the existing RSView32 project.
Hi all, so I am trying to get the correct version of RSview 32 Works to make some edits to the tag databases in some old HMIs we have. I did a...
997
Hi All, I have set up a status tag for part of my mimic but now I want to use several numbers out of it to make a valve be visible. I did try to...
1,713
I know PLCs, but I usually work with Wago or Siemens. Our customer has specified Allen-Bradley for this current assignment. I received the AB...
7,009
All, I had a HD crash and reinstalled XP, then I reinstalled all the AB software and activated it. I got my RSV SE Distributed App working on...
2,020
I'm using RSView VBA to record the last parameter adjustments made for a given product in an MS Access data base. The Access table contains...
2,346
