question about sending message between two different networks
Any Ethernet module for the ControlLogix chassis will work for this application, including the 1756-ENET, 1756-ENBT, 1756-EN2T, 1756-EN2TR, 1756-EN2F, 1756-EN3TR, etc.
The one I recommend is the 1756-ENBT, which has modern features (scrolling display, 10/100 BaseT port) and moderate performance and cost.
Ken
you know there had already been a 1756-ENBT in each PLC, do i need add another one? from the 1756-ENBT manual, i did not find the information show me how to configure for 2 different network, could you show me some?
thanks
Hi angi
If you have two cards on two different networks then as ken has said a router will do but I think you misunderstood what I said. What I often do is add another Ethernet card to one of the plc racks and set it up on the same network as the other card. The reason I do this is to keep the two network total separate . So I would just normally use a enbt
Sorry if I did not explain myself correctly
Donnchadh
Hi all I have a project on the go and would like to send data from a Siemens 1500 to a Siemens 1200 What is the best function to use ,would it be...
4,554
Hi! I want to configure our SCADALARM to send an email when an alarm occur. I configured the email addresses of the receivers but I'm having a...
3,554
Hello all, I have a servo turning a small table on a machine I'm programming. I found that after a day the home position was getting off by a...
68
Hi, I just upgraded just restored a ftview hmi data and the trend file have question marks with no lines in the graph. How do i fix this?
24
Hey all, simple question. Once I create a Macro in my Factory Talk Project, do I need to trigger the macro to run somehow? Or are all macros...
141
