Question about Unigate Cl Gateway for Ethernet I/P to Serial conversion
arbj
May 2011
mrt
61
I have been using the Anybus gateway AB7007 so far for integrating a serial device with Ethernet I/P gateway. But now I would like to use the Unigate CL Ethernet I/P gateway this one...http://www.deutschmann.de/en/products/fieldbus_iep/protocol_converter/unigate_cl/unigate_cl_-_ethernetip.html
Has anyone got experience with this ?? The anybus gateway had buffer memory for storing data extracted from transactions, so this way the slave serial device did not have to keep up with the high speeds of the network, and could process the received data at its own pace, I wonder if a similar feature is there with the Unigate Cl device ??
Also as we use a proprietary serial protocol (based on RS 485 electrical standards) I need to know if its possible to develop a script on the Unigate Cl device which would interface the serial RS485 device with the Ethernet I/P network.
The custom protocol has some similarities to Modbus RTU but is very different, I know its possible to integrate using Modbus RTU, but what about custom proprietary protocols...??
At present we are able to integrate our custom protocol with Anybus gateways easily, I wonder if the same can be done with the Unigate Cl device ??
I have sent a mail to the company asking for some answers ....
thanks
a
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
171
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
73
I have some logic that I have written within a 5380 series controller that tracks the time an event is started, while the event is running an RTO...
93
I have an HMI 2711R - T4T Series B, and I want to know which PLCs, besides Micro 820, can communicate with it.
95
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
