Question for the math professors ...
daba
Jul 2004
uk
5,401
... I followed a link dealing with Permutations and Combinations, and learnt a (to me) startling fact !
0 * 0 = 0 agreed ?
0 * 0 * 0 = 0 agreed again ?
so how does 0! = 1 ?
This has got me confused, perplexed, bamboozled, and a few other cliches.....
How can 0 * anything else not be zero ??
I looked it up. I'm not sure its deeper but it is a better definition.
Evaluate the expression 1.5!
The factorial is the product of all positive integers less than or equal to n.
The formula for a factorial is:
n! = n x (n - 1) x (n - 2) x ... x 2 x 1
Factorial Expansions are as follows:
1.5! = 1.5 x 0.5 = 0.75
Now multiply out our factorial expansions:
1.5! = 0.75
Edit: I still don't get the 0!=1 ,but I'm not a professor or a Doctor.
The factorial function is actually a continuous function. You can find the factor of real numbers too. Th function starts is not continuous for negative numbers.
n! = integrate(x^n*exp(-x),0,inf)
n is the integral of x^n*exp(-x) as x goes from 0 to infinity
1.5! = 1.329.
0.5! = 0.886
https://deltamotion.com/peter/Mathcad/Mathcad - factorial.pdf
Notice that is gets the answers you expect for all the integers including 0! = 1.
Not to provide an alternate reason to the math PeterN mentions, but I have a vague memory that when 0! is defined as one, then the binomial coefficients* can be calculated via the formula
a2457a7ef3c77831e34e06a1fe17a80b84a03181
i.e. neither denominator term will be zero when k=0 or k=n.
* see also Pascal's Triangle
The general formula of factorial can be written in fully expanded form as
n! = n·(n-1)·(n-2)·...·3·2·1
or in partially expanded form as
n! = n · (n-1)!
We know with absolute certainty that 1!=1, where n = 1. If we substitute that value of n into the second formula which is the partially expanded form of n!, we obtain the following:
n!=n×(n-1)!
1!=1×(1-1)!
1!=1×0!
For the equation to be true, we must force the value of zero factorial to equal 1, and no other. Otherwise, 1!≠1 which is a contradiction.
So yes, 0! = 1 is correct because mathematicians agreed to define it that way (nothing more and nothing less) in order to be consistent with the rest of mathematics.
n!=n×(n-1)!
1!=1×(1-1)!
1!=1×0!
Yes, but the first term on the right when n=0 is "0 x {something}". Forcing 0! to be 1 makes the equation incorrect... So, as you said, it's an agreed fudge ....
It isn't a fudge. I showed how n! can be calculated even it it is a real. Just look at the link I posted above.
n! is related to the gamma function.
If
5! = 120
then 4! = 5!/5 = 24
then 3! = 4!/4 = 6
then 2! = 3!/3 = 2
then 1! = 2!/2 = 1
then 0! = 1!/1 = 1
Simple, don't make it hard.
See attached pic Why is R02451 reading 0 before the Real_to_Int conversion? It is reading 23 after, which is what it should read.
1,692
Im using Wonderware Intouch machine edition v8.0. Question: How does the Math Worksheet/Task scripting work? I have the following expression...
2,274
Hi Group, I'm the new owner of an AB MicroLogix 1400 processor and have been trying to decide the best way to de-pressurize a compressed air tank...
1,970
🤷 I have a small cattle herd and am trying to create a feed estimate calculator. Each beast will eat about 3% of its body weight each day...
2,762
Have a question that is at the moment just not able to figure out. Lets say in a allen Bradley micrologix 14 you have a value in a floating point...
2,968
