Wonderware n00b question - Math Task
asdf6
Apr 2018
Vancouver, BC
Im using Wonderware Intouch machine edition v8.0.
Question:
How does the Math Worksheet/Task scripting work? I have the following expression mapped to a tag but it shows zero constantly but should be non-zero:
Execution = 1
Tag Name:
Tag1 (ProjecTag)
Expression
(SharedDatabase Tag1 / SharedDatabase Tag2)*100
Is this the proper syntax? I cannot find anything online that explicitly explains the general syntax for these types of expressions.
Regards,
Andre
Question:
Execution = 1
Tag Name:
Tag1 (ProjecTag)
Expression
Regards,
Andre
Please check that Tag1 and Tag2 are in Real Type or not.
Agreed; it's very likely that (Shared Database Tag1 / Shared Database Tag2) is less than 1/2.
If they are integers, then the result is rounded to the nearest integer, which is zero.
"Wonderware InTouch Machine Edition" is a brand label for Indusoft Web Studio, and the Math worksheets execute their simple "expression language".
This is in contrast to a Script worksheet, which executes VBScript.
While I'm fairly familiar with Indusoft Web Studio, the Shared Database feature is not something I have used. I would check on the values of the Shared Database Tag1 and Tag2 with the Database Spy, if you can.
You might be able to get the result you want from:
((SharedDatabase Tag1 * 1.0) / (SharedDatabase Tag2 * 1.0)) * 100
That will functionally convert Tag1 and Tag2 to REAL data type before dividing them and then multiplying by 100.
I fixed the problem by resetting Background Tasks from "Automatic" startup, to "Manual" startup, and than back to "Automatic". It seems they were initially not running.
Ken,
I did not know this, so thank you. I was wondering why the Indusoft help was so similar to ITME.
Regards,
Andre
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
163
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
110
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
193
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
186
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
171
