Question with COP instruction in Logix500
busarider29
Aug 2013
Midland, MI
399
Greetings from Michigan,
I have to edit some code that was not written by me. The existing code works but I'm hazy on exactly what is going on and/or how it works. Can someone briefly describe how the attached code works. I'm more hazy on what's going on with the COP instruction and how this is working here. The instruction documentation doesn't quite describe it written/coded this way (?).
Thanks you
the source in COP instruction is called indirect addressing.
the value after the colon in the (source in COP) have vale of N7:59.
Example:
N7:140 ------- DEst N7:133
N7:141 ------- DEst N7:133
N7:142 ------- DEst N7:133
The increment value depends on the C5:5.ACC value
the posted runs will increment every scan.
Example:
Ahhh...thank you. Got it now. :geek:
Hi All, I'm new at this, and I'm not able to understand what I believe to be strange behavior while using the COP instruction in my program. I'm...
4,336
Hello all. I have a Danfoss VLT feeding an INT into my CpLX program. I need to concatenate the MSB and LSB for position. I used a COP, making sure...
644
1769-L16ER-BB1B, ver. 24, I can't figure out why a COP instruction will not work. I'm trying to copy a string array that is in a UDT into...
1,548
So I'm trying to do some arithmetic with arrays of DINTs. However, I'm running into a problem. I’m trying to create a copy of let’s call it...
6,335
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
173
