Quick Omron CPM1A question.
Saint AAI
Oct 2007
Ollerton
22
Im trying to do a simple program on an Omron CPM1A unit. The problem I've got is using the pots on the front. It says in the manual that it the Data will appear in the range 0 to 200 in IR250 and IR251, but I couldn't find it as there didn't seem to be those addresses. So I put the PLC online and monitored the memory while I adjusted the pots and found the data in SR250 and 251. Now the problem I've got is getting it out of there and into a DM area so I can mess about whith it. I've tried using an always on input to activate a Move instruction, but I can't get it to recognise the SR250 or 251 memory areas. I've tried writing it as SR250, SR25000, S250, S:250, SR250.00 and many other ways, but it still says invalid address. So what am I doing wrong?? Thanks, Shane.
Hello SaintAA1,
Glad you got it sorted out.
Just for future reference, none of the IO areas of omron PLCs need to be prefixed when using them within your programs.
This is true for the 'older' IR / SR prefixes, and also for the "CIO" areas used in the latest CJ Series.
All that is needed (as you discovered) is the numeric address.
Hi, Anybody know if CPM1A 10 points module can add expansion module? Or only certain model support expansion (MAD01)? I'm looking for 1AI...
4,925
PLC: CJ2 series This is my first time working with an OMRON plc I am looking for some documentation on how to setup and map Ethernet IO devices...
1,776
Can someone please confirm if I'm right in thinking that the software needed to connect and program an Omron MC221 motion controller is CX-Motion...
5,091
I'm trying to import a .prj file and I keep getting the error message: Project import error. i Any ideas how to get around this? Thanks.
88
Hi, I am looking for some help with a GE Fanuc Versa Max Micro Controller model IC200UDR001-BF connected to a Quickpanel mini display...
167
