quick panel jr
srummel
Jul 2011
TN
17
I am trying to down load my first quick panel project it consists of one panel and with one button when I download it I get a message: your project has not been compiled for this display device. any help would be great thanks. the panel is 5inch monochrome qpj
Make sure that the target property 'Type' matches the part number of the HMI. Any way if you are using Proficy ME software.
More details in your question will get a better answer.
software is quick designer. panel is a quick panel jr. mo#qpj1d100l2p
I am following the instructions in the manual to the letter with the exception of the panel type is color in the instructions and mine is monochrome . it seems to be communicating with the device because I get different messages if i disconnect the cable or turn off the panel.
QPJ1, tells me that you need QuickDesigner version 2.xx, is that what you have?
Now you know why. Sorry.
QD Version 2.? Used to be a download at GEIP support.ge-ip.com.
Hi, I am looking for some help with a GE Fanuc Versa Max Micro Controller model IC200UDR001-BF connected to a Quickpanel mini display...
155
Hello, I want to plot a line on X,Y axis with defined start and end points on Quick Panel+. I use PAC Machine Edition 9.7, and it supports...
1,740
349
Hey guys, I've got a customer with quite a few 9" Quick Panel QPI-3 monochrome displays. I'm trying to replace one of them with a spare, and I...
1,315
I have an Emerson quick Panel + E15715 Does anyone know what software this takes OEM is sending a replacement under warranty but I would like...
1,203
