gareth.cantrill
- Join Date
- Oct 2004
- Posts
- 51
In the past i have used a program called Pics Pro to simulate the plant and test my code. However this is expensive. See Pantek for prices.
Another question. Why can you not 'dry test' the plant first (i.e. run the program without product running through the pipes, etc), and then if all seems ok, move on to a 'wet test' where you can simply use something non dangerous (i.e. Water).
Before all of that you should test each device individually with someone on the other end of a walkie talkie confirming that the correct device has opened or is running.
