Quickie - talking to a PLC via Citect
Johnny T
Jul 2003
Fife, Scotland
642
Hi
This is probably a question with a very simple answer but its late and I can't figure it out. If this is me being a complete buffoon then please excuse me.
I'm trying to connect a PC via Citects SCADA software, to an S5 PLC (actually 7 PLC's but if I can get one working I'm sure I'll suss the rest out).
I've set up an I/O Device in the Citect software and called it PLC1. I've told it that its going to be operating on the S5 protocol.
Now... how do I actually send something to a specific data block?
I want to send 255 words to DB11 and 255 words to DB71 in the PLC.
How do I directly address those words from my Citect software.
I tried to make a Tag up in the Variable Tag list of the type STRING, with the address DB11.DBW0 but I get a "Bad I/O device" error.
I'm a bit lost on this.. do I need to set up a different I/O server to talk to these PLC's.? Any ideas how I read and write to the data blocks??
I'm lost :-((
Thanks for any light you can shed on this
Cheers
JT :)
Check if the 'computer setup' has the projectname that you want. Your s5-plc should be 'external I/O device'
Simatic S5 _ Serial Data Types
Data Types Address Format Citect Data Type
DATA WORDS Db:w BCD / DIGITAL / INT / LONG / LONGBCD / REAL/ STRING
DIGITALS Db:w.n DIGITAL
b data block number in PLC
w word number
n bit number 00 - 15
example
Data Type DIGITAL
Address D010:001.14
Comment Digital _ Block 10 : Word 1.Bit 14
Data Type INT
Address D0010:002
Comment Data Word _ block 10 : Word 2
you can read and also WRITE data to tags
I do not have the software here and i do not know how to adres strings...so sorry on that one.
Ivo
No.. I was just wondering if there's a way of mapping a lot of data from an array into sequential words in the PLC.
For instance... I have a tag that is a LONG array with the address LO[31]
I want those elements to be mapped to DW's 0 - 31 in the PLC.
Is there a way of mapping them all across without having to make 32 separate tags in the PLC, each one pointing to an individual word?
JT :)
Does the Powerflex 40 At Reference status bit fluctuate or is it a solid at a given speed reference once the ramp completes (assuming no...
4,489
Hi, I have a customer who has cleared a virus by completely reinstalling the PC. Now the problem is he has to reset his RSLinx license that I...
2,060
Hi, can the Rades modem have a different IP range than the PLC/HMI's connected to it? I'm trying to connect to a customers site. The modem is...
2,459
Hi I found this the other day and now for the life of me i cant seem to find it again!! Where do i find the FORCE command in GX while online ?
4,948
does unitary type plc mean the same thing as Brick type? and why is there so many different names for the same parts its confusing enough
3,075
