Ramping PLC Output
tvich
Jan 2009
Minneapolis
24
Anyone out there a suggestion for ramping a PLC output for a Logix5000? I could do it with a time entry, and a gain amount, but just figure there'd be something build in for this. Ramp/Soak seems a little excessive for me.
Anyone, Bueller, Anyone, Bueller...
Try creating a tag. Each scan of the controller add 1 (Ramp Rate) to the tag
Ramp value + Ramp Rate = Ramp value (Ramp Up)
Ramp value - Ramp Rate = Ramp value (Ramp Down)
Of course you need to stop at 0 and whatever the maximum analog Output vqlue is.
Regards
Roy
Anyone out there a suggestion for ramping a PLC output for a Logix5000? I could do it with a time entry, and a gain amount, but just figure...
2,280
Hi Guys, I'm new to controls and PLCs and this might have a trivial answer. I have a small project with a PLC and a inverter. The inverter...
25
3,694
I've got a control loop controlling the speed of a pump with a VFD as a function of a flow meter measured GPM. When the GPM is increasing, I want...
1,852
I have done this before, but always looking for a better way. The application is: I have 3 AC inverters operating in open loop vector mode. I know...
1,784
Hi All, I came up with this for ramping the PWM pin on the micro 820. I'm new to ladder logic so I am not sure if this will even work? Once...
362
