Raspberry Pi Codesys 3 1734-AENTR
rssql
Aug 2006
Tn
Anyone have any experience getting a Raspberry Pi with CoDeSys to connect to a 1734-AENTR Ser. B, or any AENT?
It's using a IB4 input, and a OB8E output.
I can't seem to get the connection to work.
I called Rockwell to verify the config data.
Input: 103, 2
Output: 100, 1
Config: 102
Put in the Codesys, they are:
Config: 66
Output: 64
Input: 67
In the 1734-AENT example from Codesys, the AENT module says it's outdated.
I downloaded the current 1734-AENTR-B EDS from Rockwell, but Codesys wouldn't import it.
Thanks,
Any update? Did you get it to work?
I have a similar setup AENT/b, IB4, OB8.
I have traced my IO is configured correct and I can see my Inputs on the web page. The comms between codesys and the point IO seem to be not working correctly.
Welcome to the forum. This is an old thread. Please post here:
http://www.plctalk.net/qanda/forumdisplay.php?f=2
Include the components you are working with and their catalog numbers so that someone can assist you. Another useful piece of information might be what electrical standard (RS232, RS485, etc) and what protocol (CIP, Ethernet/IP, Modbus, etc) you are trying to use between the two devices. This will give us specifics on how to help you troubleshoot.
Hello everyone, I'm currently working on a project where I have the RPi set up as an Adapter with Codesys and the Allen-Bradley PLC as Scanner...
3,322
Hello, everyone. My supervisor recently purchased a Raspberry Pi and was curious about loading Codesys onto it for practice in the different...
8,146
Not sure if product alerts are allowed but 3S has officially released Codesys for the Raspberry Pi. 35 euros per license...
16,274
Has anyone ever tried to integrate a Raspberry Pi to a Fanuc robot? I have this idea that I want to try out but I need to write integers from a...
1,554
Hello, I have been getting more and more requests for Real Time Clock (RTC) sensitive automation from my clients. I know that there is a Modbus...
2,741
