RCD's on 3 phase socket outlets
daba
My suggestion about your RCD tripping is that somewhere down stream of the RCD, within your installation, you have an appliance with a MOV surge protector that starts conducting when it sees the spike from those lights turning off.
I know we are having problems getting mutiplug units with surge suppression built in,
The megger test is starting the 275 volt MOV conducting hence a test fail.
A unit with the MOV , Phase to N and Phase to E may be your issue.
daba
Well yes, but isn't that what the MOV is there for. The spike shouldn't be there in the first place.
So what do I have to do? Unplug all my appliances every night between 11:00 and 11:30pm so that my RCD doesn't trip?!? Not the answer to the problem really is it....
Hi all, I have an application which requires an RCD on the load side of a VSD (PowerFlex 525, 400V 3 phase, 1.5kW). I can find plenty of...
6,220
Hello, I've been iteratively re-designing the controls for our conveyor system used for educational purposes and have another question, this time...
8,058
I'm looking for how others do it. I need to start a 1 phase motor. I have always used a regular 3 phase Motor Protected Circuit Breaker and looped...
80
What would happen if you ran a 60Hz Single Phase Motor on 50Hz supply?
546
Hi all, I am having a problem with a powerflex 753 we have on site and keep getting input phase loss. The drive has been running for a long...
1,373
