Read from Modicon Micro to Proworx 32
simpleman
Dec 2015
north dakota
Help, I bought Proworx 32 V2.1 years ago, haven't used in around 8 years & forgot how to read from the controller ( all controller functions are grayed out ).
I can see the controller in the Navigator function ( shows the model, running & some other items ). But all the functions for the controller are grayed out. What minor childish step have I forgotten in my old age. PLEASE spell it out in baby steps if possible as apparently I don't know how to use this program any more.
I know enough about GW Works (Mitsibishi) to be dangerous, Rockwell to marginally get by, & just learning Idec, but Pro Worxs has me baffled. I need to swap out a Micro 110 that has damaged outputs & I need to transfer the program.
Thank you for any advice you can give.
A little background information on myself: I have been strapped to Allen Bradley/Rockwell for the last 15 years as an electromech. I've done...
1,441
We have a Modicon Quantum with an ARI 030 10 RTD card installed. We are adding a PT100 3-Wire RTD to the card. The range that we need to display...
3,453
Hello, I have a 140-CPU-534 14 Modicon processor. I would like to READ a register from a SO2 analyser. Do I need an Ethernet card or can I...
2,900
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
153
Is there a way to use the FAL instruction to do +=2 instead of +=1? I have an array that is organized with alternating "data" and "flag" values...
126
