Hi!
I am using an M200 PLC connected by Modbus TCP/IP with a Com'X 510 energy server.
I need to read the data corresponding to the voltage of a Compact NSX connected by Modbus RTU to the EBX510. My problem is that I don't know the Modbus registers associated with these parameters and when entering the NSX list registers the Read_Var block gives me an error, I don't know if the block configuration is correct. It should be noted that if I can read the data from the page of the energy server.
Can anybody help me?
Thanks.
Thanks.
