Reading a sensor directly on a PC.
Elcan
Apr 2008
NC
935
Hello all,
Let's say that we have a plant where there's no PLC or HMI, and we have a temperature sensor with a 4-20mA transmitter.
If I want to read the 4-20 signal (or its equivalent in ºF) on a PC in real time, what could be the (cheap) options to do it?
Thank you!
Hi all, i have an application in which i need to read the water level in a 1 1/2" diameter tube that is 24 in. tall. the sensor will be mounted...
27
1,989
Hello Ken Roach, Thank you for your quick reply , As informed earlier i want to read P&F Sensor data on Micrologic 1400 series B using MSG...
17
5,811
Have you seen a PT100 sensor reading going slowly up, even after heating power turned off ?! and it keeps rising for several minutes ... It looks...
4,512
Hello everyone, I have a pretty basic question which I can't seem to find any information for. I have an ultrasonic sensor connected to my analog...
3,474
166
