Kyle Grathwol
Good Morning Gentlemen,
I am using a CAN to RS232 adaptor to look at CAN data on a bus. Using Hyperterminal, the data scrolls through so fast it is impossible to read. I need to identify 2 strings by moving 2 sensors and watch for a string to change. Does anyone know of a utility that can hold each string static and by moving the sensor, I will be able to see the bits change in the string? Once I can identify the strings that I need to read I can set up a filter in the CAN to RS232 converter. Masking and scaling these strings will be another topic for you all in the future.
Thanks in advance for your help.
