Reading Citect Trend Data offline
Iman
Jul 2010
Tehran
172
Hi guys,
I want to read some data which are defined in Trend Tags in Citect 7.1. In fact, I want to specify an exact time and date to find the related value of that Trend Tag. I've found Process Analyst in the Citect but it seems to access the average of data and not a raw data. I need raw data. Is there any method to access that information?
Hi guys,
Using trends rather than process analyst will show you the actual value rather than the average, i think 7.10 had an instant trend page. You can also change the sample on Process analyst to latest rather than average.
You could also write a function to use the trend export functions to get the sample out of Citect for the time scales you need
You mention offline in your post title, if you have access to support and the Citect Toolbox there is applications in there to read the trend files directly from outside of Citect if required
I need help with vijeo citect 7.4 as I use Modbus TCPIP to get the data, it turns out the address is having error.. For example, when I write...
890
Dear All, I have a little problem in reading data from Power Meter to Vijeo Citect v6.0 I'm using Schneider PM810MG for Energy reading from...
3,292
The task I need to ultimately accomplish is deriving specific data from an XML file using Cicode. The data I would need to get would be in this...
4,519
hi how can i read string type data from registers by citect? i have defined a variable tag in form of strip type and assigned it to an object in...
1,707
Hy, I configured a Citect application that reads data from an energy meter...now i need to add to the application a time limitting reading...
9,109
