Reading Siemens logo 12/24Rco relay status on raspberry pi
Hanif
May 2008
Kar
Hello every one, i have a task to read Siemens logo 12/24Rco relay status using raspberry pi. The logo is place 3m away from raspberry pi. One option is to connect GPIO pin by pullup resistor but Vcc for pin is 3.3V and there may be some voltage drop occur as logo place 3m away from pi.
Can anyone help me to resolve this issue
How much current does the input draw? I doubt very much. If you know the current draw of the input and the ohms/metre of the connecting cable you can easily work it out.
But i wouldn't even bother, it'll work fine.
Although i am curious... why are you needing to do this? What is the RPI doing with the input?
153
I am setting up a new system and have an s7 1214 plc with an sm1231 4x AI (6ES71231-4HD32-0XB0). It is configured for 0-10v and has no faults in...
1,147
I am operating a Siemens IM151-8 F Processor with 4 6ES7-134-4NB01-0AB0 2 channel thermocouple cards. I am getting no reading from any of the...
31
6,098
I have a project where I need to get the torque reading from a G120 drive. I have communications setup over profinet. I am currently using the...
4,583
Hi All, Hope someone can help here! I have an S7-315 2DP and a MicroMaster440 talking on profibus. I have the basics fine and can read the...
4,100
