Reading values from an Analog flowmeter
valuetech
Sep 2009
Karachi
Hardware, SIEMENS S7-224XP cpu and a Flow meter (analog)
I am trying to understand if using a DIGITAL flowmeter would be easier (and economical) or an ANALOG one?
particularly, I am not sure how conveniently the averaging of the flow meter values can be done,
For instance a F/M gives a value X1 for duration T1, X2 for T2, X3 for T3, and so on....
I understand how it is to be totalled, but to do it quickly and accurately, since I've never done such an application, I would appreciate all the help I can get.
Analog for flow is fine in most cases, you shouldn't need to average , just apply some damping to the meters analog output.
I think you are asking about intergration, the easy way is to take the flow every few seconds, divide it by your frequency and add it to a register,
For example you have a flowmeter that measures in liters per minute. (for this example the flow is 30 liters per minute)
Every 6 seconds take the flow rate (30) divide by 10 and add it to your accumulator
After 6 seconds it will read 3.0, 12 seconds 6.0, 18 seconds 9.0 ------ 60 seconds 30.0
I always use 6 seconds because it divides by 10 but there's no reason why you couldn't use 5 and divide by 12
Of course if your flow meter is in liters per hour every 6 seconds you would divide by 600 and add to the accumulator.
If your PLC has a real time clock use that rather than just a regular timer.
Hope this helps
Roy
I have an OPC server running that signals when a break is happening for the shift. The OPC servis and the PLC are both connected to our Ignition...
2,670
Hey guys, Been a while, I have an odd one. Something that should be straightforward. I have a 1769-IF8 module, looking to add an analog, been in...
4,454
The values in blue are the live, monitored values and are all consistent with a cold day where our rig has.not been running for a while. So it...
1,767
Hopefully an easy one. In my program I am reading my analogue input values, low engineering values and high engineering values. My analogue input...
5,318
Hello. I am working in a lab where I need to be able to detect a certain "knock" in our machines. It happens between 2.4khz and 5khz depending...
1,269
