ssantiago Member S Join Date Mar 2010 Location Minsk Posts 28 Mar 11, 2011 #1 Hello. I have a wago 750-637/000-001 Can anyone explain me, what should i write to process image in order to get result from my sensor? Thanks.
shooter Member S Join Date Sep 2002 Location duketown Posts 2,711 Mar 18, 2011 #2 if you use the PLC configuration then add your 637 you will see a complete list with all the in and outputs, if need more find www.oscat.de for routines. and yes if wanted i can write them for you too.
