I believe I am needing to create a real time clock in ladder logic as the 1400 I am working with doesn't have one.
I will have to bring the time to the panel view and have the user input the time from the panelview (if its considerably off or by power outage reset).
I need bits to turn on/off fans on specified times
Anyone have an example of something like this that I could use as skeleton/guide rather than starting from scratch?
The Plc is micrologix 1400, 1766-132bwaa
Panelview Component 600, 2711C-T6C
I've checked the system files 'S' and there's no clock. Just the free running clock S:4. So I thought that I could start a series of timers/counters which will drop min/hour/day/month each in F: registers for use to the hmi.
Drop/move numbers in into other registers from a sceen/user input to set the time.
Take counters to set the on/off time, and place bits appropriately to control the fans.
So I'm not sure whether to a) make the clock in logic, b) use free running clock somehow, or, c) how to bring the time from the PV Component 600 to use?
