Real Time Clock in Simatic S7?
Some plc brand very easy with realtime
I am sorry that my answer not support Siemens Program.
May I post this picture for example of realtime
(very easy to use with realtime project)
I use this plc to control lighting that devided in group zone.(a little bit difference from example picture but You can do with periadical time too)
more detail
From the picture ..realtime example
When input Auto1 on ..during 4 of July from 18.00 to 21.00 pm.
firework display group 1 ..will energize for celebrate .
Opp..now 0.35 am on 9 July in Thailand .I have to turn off computer..
time and date
rgua said:
You can also in alternative:
open the OB1 block.
write these 6 lines
L LB 12 // Year
L LB 13 // Month
L LB 14 // day
L LB 15 // Hour
L LB 16 // Minute
L LB 17 // Second
Hii Rgua,
Thanks for ur reply.its very simple to find date and time rather than using SFC's
Shanmugam
Hi experts,
I managed to get the program to display the time in hours, minutes and seconds. However, i would like to know how to store this time when i activate it. For example if it is at 04:15, the system will store this time and display it.
Hello all, I know that this thread is ancient but I got an emergency question due to a paper I have to complete for tomorrow. I run the following commands on WinPLC7 (tried both v4 and v5).
L LB 12
T MB 0
I load OB1, I run the PLC, then I monitor it but the year is stuck at "0"
what am I doing wrong? HELP
No one? :(
Let me give more details. I want to write a program in which I save the date in a memory when an alarm sets off. I'm running on the WinPLC7 simulation in STL but the date I get is always "0". According to this thread the "LB 12" local data should keep the year in it... which should be 2012... not 0
Anyone has an idea what could be happening?
Hello. This is one for the Mitsubishi experts. I need to measure the time for a remote device's to return process data sent from the i-QR...
17
2,207
Hi all I thought I had this working but upon doing a checkup a few months after the machine was commissioned, I found that adjusting the RTC via...
1,892
hi all i have used a real time clock to turn on a bit after 1 month. the plc was off for this whole month and when i turned on the plc after a...
1,434
hey, anyone know how to export time from panelview 800 to micro 850 and to compare time? or distinguish various time , like to know which shift...
1,472
Hi again Looking to write date or time values to the RTC in my MicroLogix 1400 In the ladder logic I am using a CPW instruction as per the 1400...
3,315
