'Received Frame Aborted' Message
Steve Cav
Aug 2006
Clitheroe
71
I have been monitoring a DHRIO module via RSLinx and on the channel statistics screen there is one item which is giving me concern, namely the 'Received Frame Aborted'. What is this and is it something to be worried about. it appears to be steadily increasing.
Cheers
See if you can perform a Station Diagnostics monitor on another node in the system to see if the same counter is increasing.
I remember seeing this in an older 1756-DHRIO and learning that it was essentially a bogus reading on the DHRIO and did not actually indicate bad frames. I think this was related to the DHRIO being on a network with an old 1785-KE bridge to a DCS system.
If another node confirms the same behavior, or if this DHRIO is a newer one (Series D or E) then you might have some noise problems on the network.
The DHRIO modules are unfortunately series B revision 2.14. As far as performing a Station Diagnostics on another node, all the other nodes are PLC5 Processors (12 of) and one Pyramid Integrator.
I'll check the Processors for diagnostics but doubt it will show the number of frames aborted.
Strictly speaking what is a 'bad frame'.
Also upgrading to the latest firmware will probably require a plant shutdown - not an option for now.
Were those the only files? Megabasic files have the suffix .bas You can probably get along without PCOP. Termf is sufficient to do whatever you...
184
I received this by PM. I prefer to keep the discussion on the forum. Hello ! I managed to connect to PLC GE 90-30. I don't know the Proficy...
1,161
I just got this via PM I prefer to keep the discussion on the forum. Can you be a little more specific? What is the nature of your trouble? Are...
671
I got this PM this morning. I prefer to keep the discussion on the forum. There are two default passwords in a PanelMate. I would try them...
875
I got this request via PM. I prefer to answer in the forum instead of in private. Hello Steve! How are you? Hope you are good right now. I saw...
873
