recipe saving?
jcraft
Dec 2006
Niagara falls
91
We have a machine in the facility running a GE 90-30 rack. connecting to the rack is a standard desktop PC with a 15" display running Cimplicity HMI software. THe machine program and Cimplicity program have been in place and operational for many years. I don't have any experience with writing/programming any recipes in Cimplicity. I basically provide troubleshooting as needed. Here is the issue,the operators usually enter recipe data on the machine screem HMI at the beginning of part runs. over the weekends the machine power is shutdown however the computer and PLC stay powered up. In any event this morning the power due to a utility issue went down and the entire facilty went out for 10 minutes or so. When the machine was powered back up all recipe information that was in the HMI was gone and all needed to be re-entered. Was wondering at this point how axactly recipes are stored in the HMI and how would they be lost. I don't run the machine but I beleive there is a button on the recipe screen that says save to a file. MAybe someone didn't save them last time they were entered. Any other thoughts what would cause this. Thanks for the help.
Just a quick reply with little detail.
There is an option in Cimplicity called "Saved Point Storage". You can enable it to save all point data at project shutdown. This assumes that the project is shutdown properly. It does take some space to utilize, but any current point information is written and (I think) retrieved when the project restarts.
Otherwise, I would consider an autosave or forced save. Don't apply any of the entered recipe until the user clicks save.
I'm using a 1769-L16ER-BB1B. I'm storing recipe data in an array of user-defined data types. For disaster recovery purposes, I need to make sure...
8,910
I'm trying to save the recipe file from the plc to the PC, I have tried saving while online but I don't see it when I'm offline. The recipes are...
2,048
I am having trouble saving the recipe to an e-150 terminal The software is ver.6.10, the plc is the fx1s series mitsubishi some of it is saved and...
3,462
I have a micro1400 processor running two routines (transfer compression/compression molding press). Recipe parameters are stored from job to job...
67
I'm using legacy recipe to download a recipe to the PLC. A little background, the recipes are large. They are broken down into 6 tables, each 16...
124
