Recommended cabling for brake resistor
einnh
Mar 2014
New England
275
Is there a recommended cable type for braking resistors? I had been using DLO wire but I feel there has to be a better options.
From literature it is recommended to use a twisted pair, screen shielded wire. 90C or higher.
Problem is I need 2 AWG wire for this project.
This project has a 46kW resistor, 60kW 480V PowerFlex drive. So bus voltage is 200 - 815VDC (648VDC nominal, 750VDC to brake)
Any help would be greatly appreciated. Just waiting to hear back from our wire guy.
Thanks,
E
About 12 years ago I recall buying a special high temp wire for brake resistors. I believe it was a teflon based insulation that looked like a woven cloth.
A quick google search found this site with a picture on the right that looks like what I found.
http://www.daconsystems.com/custom-wire-manufacturing/high-temperature-wire/
The picture on the right looks like what I used. The machinery I was working on had been wired with THHN and it wasn't holding up very well. Not only was the insulation melting near the brake terminals but the connections were losing their integrity. The high dollar wire seemed to solve the problem for us. This was on winding machines that used the brakes quite frequently.
Out of interest, I'd like some thoughts on what would be considered best practice with regards to a 2-position turntable control scheme (see...
17
1,155
Hello all, I have a client that needs to externally control some valves at a small plant, nothing fancy. (for which I just need digital IO)...
3,933
We are going to be using a SIRUS 3RW5545 Soft Start to control a 480V, 150HP fan. Looking for some recommendations for parameters to use with this...
852
Good Afternoon , I'm getting ready to lease a lot of Rockwell Software. I really don't have any desire to go the VM route , just because I'm...
2,020
I wanted to get some opinions and maybe a point in the right direction for products on networking machines for data collection. Im not all that...
4,852
