Red Lion CUB5/G306A Communications Problem
gamefreak32
Jun 2012
NC
I've got an encoder hooked up to a CUB5 and want to communicate with it from a G306A via RS232. I made two cables with pinouts per the G306A and CUB5 manuals, programmed the G306 to communicate with it, and I'm getting nothing.
The CUB5 is the only device connected to the RS232 port on the G306. I'm using the RLC Instrument driver for the CUB5. I've checked the baud rate, data bits, and parity in both. I've got the port enabled in Crimson and changed the drop number in both to match.
The only thing I can figure out is that the address in the Data Tag is wrong. I'm looking for the count. I've tried a number of combinations and have nothing. I've tried the values A, CT, CA.
Anyone have any suggestions of things to try?
Im using the red lion cub5 for the RPM of a motor. I was wanting to see if it was possible to get the data from the meter to a allenn bradley PLC.
160
Hello! Does anyone have a listing of the un-documented setup commands for the CUB5 series meters? I'm trying to write a pc based program that...
1,839
Trying to get this thing to COUNT. Just a simple count, no math or anything. I want it to increment on an output from a Siemens 305 PLC. I tried...
3,531
91
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
299
