Red Lion CUB5 #CUB50000
John O'Hara
Feb 2003
Ohio
Trying to get this thing to COUNT.
Just a simple count, no math or anything.
I want it to increment on an output from a Siemens 305 PLC.
I tried ground level & tried 24vdc.
Nothing works.
I am able to tell it to reset to factory settings.
This thing is more complicated than I need at this time.
At this time, I do not want dualcounter.
Maybe later?
I just want to know WHAT to send it so it will count.
If you do have a CUB50000 (the older model) the all you need to do is have the output of your PLC short Input A to Common. If you are using a relay, it will more than likely chatter and cause it to count by more than 1. All you need to do is tie a jumper between Filter A and Common to add in a low-pass filter to overcome the contact bounce.
Regards,
Dan
Thanks Dan, That sounded simple enough. I still can't get it to count.
I tried what you suggest using a jumper-wire from Inp-A to common. No count. Tried Inp-B as well...no count. Jumped the Filter-A to common...no help. Maybe it is defective?...but I did get it to count awhile back, but don't remember what I did? I do remember it was not easy. Back then, I did see bounce (more than 1 count)but now I can't get any counts no matter what.
It is odd that I can go thru the programming Ok. I seem to remember that was the key back then, but now I have reset it to FACt SEt repeatedly after trying all kinds of various settings.
I may throw this one in the wood-burner soon. I will then look for one of the newer ones if they are the same size, as I already cut a hole in my control panel for this one?
I just d/loaded the newer intruction sheet & the old & new are the same dimensions.
John
Still trying....
I just got it to count...albeit wildly incrementing. I turned Rate enable OFF. Now Inp-B causes a wild count using my jumper-wire.
At least it is not DEAD.
I am now going to add the Filter-B jumper.
I did that. I also put Inp_B on a relay ouput with the PLC card sourced to CUB's common....
It works !!!
I don't know why Inp-A is deaf, but I am getting somewher anyhow.
That is good to hear. I have asked on the the panel meter guys to sign up to help out. I have not suuported the panel meters in 4 years, so I am a bit rusty.
Regards,
Dan
It's now counting using INP_B with filtering triggered by a relay card on PLC. That is all I need right now. I may play with it later for other features? The only delema now is that I had to add a relay card to the PLC. The commons on these go to 4 potential outputs. So I waste 3 outputs, just to use one, being that the card common goes to common on the CUB5, which is of no other use to me for the other 3 relay ouputs. I guess I can utilize 1 other relay output to the CUB common by programming the 'program' screw of the CUB to another relay output. This way, I can force an output to it, and enter program mode of CUB5. This will allow me to NOT allow reset of counter via CUB5 front panel, only when I force the output and enter program mode to allow reset temporarily.
SO...I am good to got for what I want to do. CUB5 is real powerfull, but overly complicated for my app.
Docs for it should provide examples for at least the simplest of count jobs, in my opinion.
Im using the red lion cub5 for the RPM of a motor. I was wanting to see if it was possible to get the data from the meter to a allenn bradley PLC.
152
I've got an encoder hooked up to a CUB5 and want to communicate with it from a G306A via RS232. I made two cables with pinouts per the G306A and...
1,933
Hello! Does anyone have a listing of the un-documented setup commands for the CUB5 series meters? I'm trying to write a pc based program that...
1,824
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
271
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
282
