Red Lion Ethernet Port Routing
Rube
Sep 2003
Fort Worth, Texas
958
Morning folks. I have a RL G315, with two Ethernet ports, running Crimson 3: 1 is connected to components in my MCP, (PLC, VFDs, etc.) and 2 is connected to our company network:
Ethernet 1. IP address is 192.168.98.xxx mask 255.255.255.0 gateway 0.0.0.0 (MCP components)
Ethernet 2. IP address is 10.3.35.xxx mask 255.255.0.0 gateway 10.3.35.1 (company network)
Laptop 1. (Wireless) IP address is 10.3.7.52 mask 255.255.255.0 gateway 10.3.7.1
Laptop 2. (LAN) IP address is 192.168.98.200 mask 255.255.255.0 gateway 0.0.0.0
The PLC to G315 comms are working fine on Ethernet 1. My laptop to G315 comms are working fine from Wireless to Ethernet 2. My laptop to PLC comms are working fine from LAN to PLC. My wireless comms from the laptop, through the G315, to the PLC--no good.
What entries do I need to make in the routing table in order to communicate from the wireless on my laptop, through the G315, with the PLC? All the variations I've tried have gotten me nowhere.
Does the routing table route from Ethernet 1 to Ethernet 2? Vice versa? Both?
I know I'm close to getting where I want to be but any assistance would be greatly appreciated!
Hi All, I am hoping someone can help. I have setup a Red Lion Data Station (DA30D, Crimson 3.1 Build 3112) to log data from several Allen...
18
7,353
I'm having an issue with setting the network port mode and ip addresses with data tags. I'm using a Graphite with the auxillary ethernet port. I...
1,113
Hi, I have a 2-Rack CLX. I am communicating to a Red Lion Data Station Plus through a 1756 Ethernet Module in Rack 2, Slot 1. The CPU is in Rack...
1,002
Hello Everyone, I have a Redlion DSPSX000. When I first powered it on I was able to Download the configuration in it with USB. After That I...
1,466
Hi guys, Somebody knows the driver that has to be selected to setup communication between two Red Lion HMI's? Thanks.
1,693
