Red Lion Graphite ethernet data tags
ERCfarcontrol
Apr 2015
Fresno, Ca
63
I'm having an issue with setting the network port mode and ip addresses with data tags. I'm using a Graphite with the auxillary ethernet port. I was successfully changing the port modes and IP's with data tags in the office.... set the IP data tags on screen, wait for the retentive tag storage write interval to back up the tags, then cycle power.
Yesterday I tested this in the field and all settings are set properly except the gateway address's. When I make a change to either gateway address it applies the change to both of the ethernet ports. I'm boggled. Is there something I'm missing about the gateways of dual ports?
A couple of unrelated questions...
1)Can the webserver only be used on one ethernet port?
2)What is the time interval between the writing of the retentive tags to memory?
I'm trying to use a Red Lion Cub counter (Cub5B00) as a counter and give the cub's counts to a Graphite G12 PLC/HMI to display. After about an...
114
Does anyone know a quick answer to the difference of a red lion G10C1000 vs G10C0000. In crimson it shows an aux ethernet port. on the web site i...
1,455
Hello all. I am struggling with an analog output from a Red Lion Graphite HMI with a GMOUT4 module. I can watch what the data should be (currently...
1,373
I have a graphite HMI and 3 PAX panel meters. I have tried using RLC and Modbus Master drivers, 2 different cables, with and without Comm...
1,878
Hi Everyone, Got a new project where I am going to read the level of a tank via Modbus and I need to use the tank strapping chart to convert it to...
2,531
