Red Lion G304K2 - "Error: unable to open firmware file"
Jimmyqr
Sep 2014
QLD
Hi all
I am trying to upload a database to a brand new one of these, using latest crimson 3 software.. this is the first time i've used one of these so everything's just been downloaded from scratch.
While it seems to be communicating OK, it stops with the error:
Error: Unable to open Firmware File
This happens just after it reboots the device, so a few seconds after hitting send.
I am not sure if it's trying to open a local file to update, or the firmware on the unit, but i've tried everything I can think of:
*Running as administrator (win 7)
*Creating a fresh new empty database , and trying to upload that instead
*Database clear (was brand new and empty anyway)
I'm about to go out to site and try to upload (extract) the DB out of the smaahed one I'm replacing (still runs but touchscrene smashed) but if anyone has any ideas would be greatly appreciated
THANKS!
OK so it turned out the existing database was 304K not K2!
New problem now though. I can't communicate with it at all once I've downloaded a database. Once it's booted and executing, that's it. Yet I see no way to stop execution, or prevent it starting up.
Anyone know what i'm missing? :confused:
On the G304k2 you have to have a way in the database to call the StopSystem() function.Otherwise you have to clear the database on start up.
Hi all, I'm having programs connecting to a G304K2 over Ethernet to transfer the screens. I know on the older models, you first had to do a...
3,323
Hi guys, I have several Red Lion Kadet G304K and G304K2 terminals in service, and one particular client has now returned two of them with smashed...
2,951
Red Lion Crimson3.0 buttons G304K2 The background image changes, and I see that you can Move the text on press. Is there any way to have the text...
6,085
I have a Red Lion Cadet G304K2 HMI that I want to use to communicate with CompactLogix 1769-L30ERM using Ethernet/IP Is there a tutorial or...
12,394
I have a G304K2 connected to an Allen-Bradley L16ER Compactlogix processor. When the two are connected everything works as it should for several...
3,667
