Red Lion G306A Compactflash access via ethernet
OkiePC
Mar 2005
ENE of Nowhere Oklahoma
11,794
Okay, I finally got the noise issue under control on my checkweigher project and it is weighing boxes and logging them to compact flash.
When I was testing the PLC hardware and G306A in the lab, I was able to mount the card on my PC via the USB connection and open the csv files.
Now that the machine is out there on the floor, I need to learn how to retrieve those files via the LAN since USB is not available. I can "remote in" to the G3 webpage and remote control the thing, but when I choose "View Logs" I get a 404 error in the browser (IE8). This might be because I am creating custom logs, but I would expect that I should still be able to view the system logs...not sure.
Also, I have read the very short section on FTP in the Crimson manual, but I am not sure how to set that up. I see a FTP enable checkbox and a security setting, so what next? I know what FTP stands for, and that's about the extent of my experience with it, but I have confidence in the forum's ability to educate me!
Thanks,
Paul
I dont know if this is how the RedLion does it, but the AD C More works like this. Enable the ftp server. Then in your web browser address window type FTP://your ip address here. This should access the directory in the HMI.Give it a try:beerchug:
Paul you can use the FTP to log those to a PC for you. I did this on a job and had NON PLC folks (read IT guys) look at those numbers daily
Paul
Enabling the FTP server allows you to manually view and retrieve the files from the card as you have already done. You can also go down the route Jeff mentioned, which would be the SyncManager. This turns the unit into an FTP client and allows you to have the files pushed to a server on a preset time basis.
Jeremy
Trying to get a G306A panel to talk to an SDM120CTM meter but i can't make the Red Lion make sense of the response from the meter. Using PC...
852
Looking for some help on the red lion side I was able to diver out all the port settings to get the hmi to talk to elc having the are-485 light to...
1,106
Just getting into learning the Crimson 3.0 database software and I need some help. I am trying to figure out the reason why the G306A will not...
4,302
Good Day Everyone! We have a project the requires an encoder connected to a Paxi Meter and then into the HMI in order to display/record depth and...
3,157
I've got an encoder hooked up to a CUB5 and want to communicate with it from a G306A via RS232. I made two cables with pinouts per the G306A and...
1,927
