Red Lion G306A
CharlesM
Aug 2005
Arkansas
1,129
I just ot my first G306A. I found a way to adjust the contrast but I have not found a way to change the brightness. Is there a function to change brightness?
Also it seems like some colors are better than others for backgrounds. What colors work best/worst?
Modify the DispBrightness system variable (i.e. DispBrightness:=0 is minimum, DispBrightness:=100 is maximum).
Trying to get a G306A panel to talk to an SDM120CTM meter but i can't make the Red Lion make sense of the response from the meter. Using PC...
867
Looking for some help on the red lion side I was able to diver out all the port settings to get the hmi to talk to elc having the are-485 light to...
1,112
Just getting into learning the Crimson 3.0 database software and I need some help. I am trying to figure out the reason why the G306A will not...
4,310
Good Day Everyone! We have a project the requires an encoder connected to a Paxi Meter and then into the HMI in order to display/record depth and...
3,171
I've got an encoder hooked up to a CUB5 and want to communicate with it from a G306A via RS232. I made two cables with pinouts per the G306A and...
1,946
