Red Lion G308 Logging Question
Peat
Oct 2010
New Jersey
Hey guys,
I am using Crimson 3 to program a G308. My question concerns the naming of the data logging .csv files.
I want to create a coded file name based on 4 inputs from the touch screen.
The four variables will change and want to just log the data for that cycle.
The code will be such as WWWXXXYYYZZZ. I wanted to know if it is possible to change the name of the csv automatically based on those variables.
Thank you for you help.
I don't think you can control the file naming of the built in data logs.
There's no reason you can't create your own logging programs.
There are commands to create directories and create files, so that you can name them as you wish.
If you create a custom log file and put it in the /logs/ directory, then you can still access them through the web interface.
After looking at the documentation further I did notice that the logs default to YYMMDDhh.csv format.
I might play around with the function RenameFile(FILE, "name) and see if I can modify the name to what the customer wants.
Thanks for your help. Will post with what I came up with when done.
You will need to use OpenFile ("NAME", Mode) to get the file Handle which is a number that you'll use with the Rename function.
Example:
Handle:=OpenFile("10011308.CSV",0); //Open file read only...not sure if read only mode will work for the rename function
RenameFile (Handle, NEWNAME); //NEWNAME is a CString built based on the datalog configuration.
CloseFile(Handle);
I think you may run into trouble if the logger is still using that file. It may create another one the next time it triggers. I am sure one of the Red Lion gurus will see this thread and correct any mistakes or doubts we have about this.
Peat,
OkiePC is corrrect in that you can't alter the way the logger names its files. If you wish to do custom naming you will have to create your own logger.
In order to use the rename function you will need to know the name of the file, which would probably be your biggest hurdle.
Jeremy
Hi, I am going to try and download a database to a G308 via the serial port. Reading the Crimson 3.0 manual I cannot find anything about port...
2,817
Hi all, I have a customer that wants me to send a email based on a specific event. I have created a trigger that creates a Data File based on...
3,294
Hi everyone, About a year ago I built a panel for a customer that has a ML1400 and Red Lion G308 HMI. He now wants to talk to the PLC with his...
2,759
I am having some fits with my new project. Here are the details of the system: PLC: 1769-L33ER v21.11 RsLogix Studio V21 HMI: G308C100 Crimson...
22
9,479
Is there a way to connect an IP camera to a G308 and use a touchscreen page to view the video? We have a machine with a carriage that moves and...
2,256
