Red Lion G308 to S7-313C MPI comms
dellae
Sep 2005
Papatoetoe
18
I am trying to get a G308 to talk to an S7-313C (MPI int) without any luck.
I have tried 232 & 485 connections as per Red Lion cables and can't get any response.
I have tried setting the PLC down to 19.2k.
I have a breakout box in between and I see the screen is polling but there is no reponse from the PLC.
Anyone know the trick with these. (Siemens don't want to know of coarse)?
Ta
Are you using a MPI converter between the G3's 232 port and the PLC? A MPI HMI adapter is required for the communication. We sell the Helmholz SSW7-HMI, and I have also successfully used the Siemens 6Es7 972-0CA10-0XA0. Some customers in Europe have also used one offered by Process Informatik, although I am unaware of the part number.
The RS485 cable is for PPI communications to a S7-200 PLC.
Regards,
Hi, I am using the 232 port with a Siemens P6ES7 972-0CA23-0XA0.
I have made a CBLSIE02 cable and the D9 adapter.
I have checked that the appropriate pin from the RLC RJ12 is connected to the D9 pin as per the drawing.
I figured it should be straight forward and therfore I must be doing something wrong but haven't yet figured what.
The adapter is your problem. The adpater you are using is the PC adapter which is used for programming the PLC. A separate HMI adapter is needed for communications to the PLC.
Regards,
Thanks very much for that.
I knew I shouldn't have been such a bloke and asked for help here a week ago.......................
Any time you have a problem with one of our products, feel free to at least send me an email and I will try to help you any way that I can.
Regards,
Hi, I am going to try and download a database to a G308 via the serial port. Reading the Crimson 3.0 manual I cannot find anything about port...
2,817
Hi all, I have a customer that wants me to send a email based on a specific event. I have created a trigger that creates a Data File based on...
3,294
Hi everyone, About a year ago I built a panel for a customer that has a ML1400 and Red Lion G308 HMI. He now wants to talk to the PLC with his...
2,759
I am having some fits with my new project. Here are the details of the system: PLC: 1769-L33ER v21.11 RsLogix Studio V21 HMI: G308C100 Crimson...
22
9,479
Is there a way to connect an IP camera to a G308 and use a touchscreen page to view the video? We have a machine with a carriage that moves and...
2,256
