Red lion Graphite/Crimson 3 bar code reader
Edmhydraulics
Apr 2014
Beaumont
173
I have had an interesting request from a customer. I have sold them a graphite based system and he was wondering if we can use a bar code reader to import into data fields? Any thoughts on this or has anyone ever tried it before.
Edm
Edm
If you touch the field (Tag with Data Entry allowed) on the display and then scan the barcode, it will be just the same as if you typed it. Of course, the data has to be a valid type for the field.
The issue I have run into is that the reader that I bought wouldn't always power up from the USB Port on the display (I only tried this on a G315, not a Graphite). However, there isn't any setup required to get it to work. It acts just like a keyboard (really neat actually)
Jharbin, thats very interesting, do you happen to remember the type or manufacturer of the bar code reader you bought.
Edm.
I just ordered it from Amazon and it was $25.00 or so. This was just for a test and the application never panned out so I didn't try to order an industrial one.
I'm trying to use a Red Lion Cub counter (Cub5B00) as a counter and give the cub's counts to a Graphite G12 PLC/HMI to display. After about an...
114
Does anyone know a quick answer to the difference of a red lion G10C1000 vs G10C0000. In crimson it shows an aux ethernet port. on the web site i...
1,455
Hello all. I am struggling with an analog output from a Red Lion Graphite HMI with a GMOUT4 module. I can watch what the data should be (currently...
1,373
I have a graphite HMI and 3 PAX panel meters. I have tried using RLC and Modbus Master drivers, 2 different cables, with and without Comm...
1,878
Hi Everyone, Got a new project where I am going to read the level of a tank via Modbus and I need to use the tank strapping chart to convert it to...
2,531
